# How Product Marketers Can Use Data to Drive Up Adoption
Grow your product with better adoption. Benjamin Brandall, Head of Marketing at Chameleon, explains how to use data to improve onboarding and retention.
Source: https://amplitude.com/en-us/blog/how-product-marketers-can-use-data-to-drive-up-adoption
[Benjamin Brandall](/blog/author/benjamin-brandall)
[Head of Marketing, Chameleon](/blog/author/benjamin-brandall)
[](https://www.facebook.com/sharer/sharer.php?u=https%3A%2F%2Famplitude.com%2Fblog%2F%2Fblog%2Fhow-product-marketers-can-use-data-to-drive-up-adoption)[](https://www.linkedin.com/sharing/share-offsite/?url=https%3A%2F%2Famplitude.com%2Fblog%2F%2Fblog%2Fhow-product-marketers-can-use-data-to-drive-up-adoption)[](https://twitter.com/intent/tweet?url=https%3A%2F%2Famplitude.com%2Fblog%2F%2Fblog%2Fhow-product-marketers-can-use-data-to-drive-up-adoption\&text=How%20Product%20Marketers%20Can%20Use%20Data%20to%20Drive%20Up%20Adoption)[](mailto:?subject=Checkout%20this%20Amplitude%20Article\&body=Check%20this%20out%3A%20https%3A%2F%2Famplitude.com%2Fblog%2F%2Fblog%2Fhow-product-marketers-can-use-data-to-drive-up-adoption)
Most SaaS products are in a constant battle against two dark forces:
1. High churn—You acquire users but lose them quickly because of broken onboarding.
2. Shallow feature adoption—Most users only engage with part of the product and tend to ignore new features.
It’s a battle to both stabilize the health of your new users, and deepen engagement and adoption for existing users. Since everything in business seems to be some sort of funnel, let’s represent these problems with a quick look at the [product adoption process](https://amplitude.com/explore/product/what-product-adoption):
*([Source](https://www.trychameleon.com/blog/principles-product-feature-adoption))*
The user onboarding process spans almost the entire funnel above—improvements to your product’s onboarding help move users through every step faster. Hidden in the last step (adoption) is the second battle, to deepen usage and engagement.
In this article, I’ll look at approaches you can use to detect, analyze and combat these problems so you can drive product growth from the inside.
## Patching a leaky user onboarding funnel
For mobile apps, freemium SaaS, and even enterprise software, nailing the onboarding process is a big problem.
*([Source](https://www.trychameleon.com/blog/live-chat-user-onboarding))*
Acquiring a new user costs 25x more than retaining an existing one, so while there’s danger in ignoring first-time use there’s also the opportunity to make a big impact with small improvements.
With [Amplitude](https://amplitude.com/), getting a look at your product’s onboarding effectiveness is easy. You’ll need to select an event that signifies a new user starting a session in your product as the start point, and then compare that against the number of users that hit a key retention milestone, or [aha moment](https://www.trychameleon.com/blog/successful-user-onboarding).
##### Related Reading: 4 Steps to Measure User Onboarding the Right Way
Every app’s aha moment is different; a good methodology to find it is to look at the events that engaged users do, but disengaged users *don’t* do. For an email marketing tool, that could be setting a campaign live or uploading a list of leads. At Chameleon, we correlate whether or not a user installed our Chrome extension with retention. Using Amplitude we found that users who install the extension are more than twice as likely to hit a key retention milestone and stay retained after 12 weeks:
##### Every app’s aha moment is different.
*Using Amplitude we found that users who install the extension are more than twice as likely to hit a key retention milestone and stay retained after 12 weeks.*
So, you’ve got a signup event and an aha moment. To examine the correlation between them, run funnel analysis in Amplitude and check the percentage drop-off.
*Funnel analysis in Amplitude.*
No one can tell you what a good activation rate is for your product; it’ll vary wildly based on whether you’re B2B, enterprise-focused, or freemium—basically depending on how qualified your leads are in the first place.
For self-serve products, this is a challenge because unqualified tire-kickers will pollute your data, but over time you’ll set a benchmark. According to Pulse Insights founder Jeremy Bieger, activation rate for free trial users on a low-cost product averages [10%](https://www.quora.com/What-is-a-good-activation-rate-for-a-B2B-SaaS-product), rising significantly for products with more qualification built into the sales and evaluation process like those with enterprise pricing, paid pilots, or required credit cards during signup.
Assuming that 10% of users end up sticking, by improving that number to 15% you could see a 33% increase in MRR, or even more over time:
*([Source](https://www.process.st/why-is-customer-success-important/))*
That brings us to the driving action part. How can you improve your onboarding? How do other companies do it?
Take Voxox as an example—an enterprise software company who were struggling to onboard new users to a product they had just launched. It’s not often you get access to other company’s metrics on user onboarding, but we’re uniquely situated to get an insider look at Chameleon. Voxox found that the difference in retention between users that saw an onboarding flow versus those that didn’t was [50%](https://www.trychameleon.com/customers/voxox).
Here’s a quick gif of the onboarding flow they built:
*([Source](https://www.trychameleon.com/customers/voxox))*
Quick tips to improve your user onboarding:
- Inspect the full onboarding experience from different angles and grouped by different segments. Do admins have different aha moments to average users? Is your product complex, with multiple aha moments?
- Don’t think of it as training, or explaining. You’re marketing when talking to new users. They’re at high risk of not caring unless given a concrete reason to. So reflect that in your copy and the actions you request they take within their first 5 minutes in your app.
- Remember onboarding doesn’t start and end with a landing page, email campaign, or tooltip. It’s a long journey, and no two users will take exactly the same path. Tightening up your onboarding is as much about nailing the first-time-use experience as it is about setting expectations before the user even touches the interface.
##### Related Reading: How to Choose a User Onboarding Stack That Drives Retention
## How to measure feature adoption with product analytics
Solving the onboarding challenge helps you get new users through the high-friction trial by fire of building new habits and skills, but it’s only one piece of the product marketing puzzle.
Engaging existing users by helping them discover new value within your product is equally important. You can have the slickest activation flows, but if users only get value for a month before getting distracted by another shiny object, your LTV will be low. According to UserIQ, nearly 50% of companies surveyed (mainly in the B2B enterprise space) have no formal approach to driving feature adoption.
Low customer lifetime value? Product marketing to the rescue! Let’s first look at how to measure feature adoption with [product analytics](https://amplitude.com).
Assuming your feature has unique, tracked events associated with it inside Amplitude, getting a pulse on adoption is as simple as looking at the total count of uniques and the active percent of users who have performed that event.
Although for a full picture there are more ways to slice the data and get insight.
*([Source](https://medium.com/@tsharon/measuring-user-adoption-b367eb32d619))*
Here’s one way to measure adoption—the percentage of active users that interacted with a feature over time:
*Amplitude chart of the percentage of active users that interacted with a feature over time.*
In the chart above you can see there was a burst of interest when the feature was first launched, which waned over time before picking up again briefly due to an in-product announcement.
Users not getting deep enough into your app’s valuable functionality is a problem that can be solved from a few angles. To map out how users engage with a feature (and why more users aren’t adopting it), look at your existing feature announcement strategy and the channels that drive the most action.
SaaS companies have multiple channels at their disposal when announcing new features…
- Release notes
- Blog posts announcing the feature
- Blog posts demonstrating use cases
- Webinars to customers (select beta users before a larger rollout)
- Email announcement to customers
- Editing existing in-app copy
- Deploying new in-product messaging
It’s our view that companies should experiment with all of these tactics and see what sticks, but we’ve found that at a minimum, companies should do [two things](https://www.trychameleon.com/blog/you-need-emails-and-in-app-messages-for-user-onboarding):
1. A **focused email announcement** that reaches both active users and those slipping away, to resurrect a portion at risk of churn and delight engaged users with an update
2. A **contextual in-app campaign** like a tooltip or tour, to highlight the feature and sell value to the user while they’re engaged and ready to try it.
In-app campaigns are great for engaging active users with a new feature because sometimes the product’s UI alone isn’t enough to signal a significant change—let alone give users a compelling reason to deviate from their usual habits.
##### In-app campaigns are great for engaging active users with a new feature because sometimes the product’s UI alone isn’t enough to signal a significant change
Urban Airship, a SaaS company that makes mobile marketing software, found that one in-app prompt drove 10% of its user base to adopt a feature upon release. Considering that the industry standard click rate for SaaS emails is just over [2%](https://mailchimp.com/resources/email-marketing-benchmarks/), the conversion rate boost that comes with a contextual, in-product prompt is huge.
Announcing features in-product is a channel used in launches by a ton of SaaS companies including [AngelList](https://www.trychameleon.com/inspiration/angellist-jobs-new-product?tag=feature-announcement), [Stripe](https://www.trychameleon.com/inspiration/stripe-invoices-tooltip?tag=feature-announcement), and [Moz](https://www.trychameleon.com/inspiration/moz-feature-announcement-tour?tag=feature-announcement):
Quick tips to improve feature launches:
- Refine the launch’s messaging and adopt early users by running a small beta with a few of your top customers. This doesn’t scale easily, but hosting webinars for beta users and engaging with them in your company Slack can help you as a product marketer looking for insight, and them as the user adopting a valuable new feature.
- Create content—whether that’s blog posts, tooltips, or demo videos—that shows the feature’s use cases and benefits. Just explaining functionally how a feature works won’t motivate users enough to get over the friction of trying a new thing.
- Use Amplitude to compare feature adoption KPIs against users that touched the launch and education campaigns you ran; double down on the most effective channel next time, and keep experimenting with different cadences and CTAs.
## Conclusion
Product Marketers are tasked with both bringing more users into the product and ensuring those users stick. Really nailing the formula to make that happen is part science, part alchemy—because it’s different for every product.
With sophisticated product analytics, it’s possible to query user behaviours and draw accurate correlations between changes you make and factors like activation and retention.
A combination of Amplitude and Chameleon allows you to target in-product prompts to based on your existing user data (attributes, events and segments). With the right stack, Product Marketers can take on the role of scientists, and constantly run experiments that drive product growth. Learn more about the integration [here](https://www.trychameleon.com/integrations/amplitude).
Benjamin Brandall
[More from ](/blog/author/benjamin-brandall)
[Benjamin](/blog/author/benjamin-brandall)
Benjamin Brandall is Head of Marketing at \[Chameleon]\(https\://www\.trychameleon.com/). When not obsessing over SaaS, he's probably programming silly bots in Ruby.
