# Duplicating Across Projects and Platforms
Source: https://amplitude.com/docs/guides-and-surveys/duplicating-guides-and-surveys-across-projects
On this page
- [Duplicate across projects](#duplicate-across-projects)
- [Duplicate a guide or survey across projects](#duplicate-a-guide-or-survey-across-projects)
- [Duplicate a theme across projects](#duplicate-a-theme-across-projects)
- [Re-duplicate a guide, survey, or theme](#re-duplicate-a-guide-survey-or-theme)
- [Duplicate across platforms](#duplicate-across-platforms)
- [Duplicate a guide or survey across platforms](#duplicate-a-guide-or-survey-across-platforms)
Your organization may have multiple projects for different reasons. For example, you may use separate projects to differentiate between environments (such as staging and production) or between geolocations. Duplicating a guide, survey, or theme across projects or platforms saves you from recreating the same content for each environment or app, which saves time and encourages consistency.
Duplication in Experiments
You can't duplicate a guide or survey across your projects if it's part of an experiment. If you want the same guide or survey in experiments in multiple projects, you must manually recreate it.
When you duplicate a guide, survey, or theme to a new project, the new project treats the duplicated content as a new entity. Amplitude doesn't copy previous analytics to the new project. To move a guide, survey, or theme from one project to another, copy it to the destination project, then archive it from the originating project.
## Duplicate across projects
### Duplicate a guide or survey across projects
1. Navigate to *Guides and Surveys > Guides* or *Guides and Surveys > Surveys*.
2. Click the **three-dot** menu for the guide or survey you want to duplicate.
3. Click **Duplicate across projects**.
4. Click the **Destination** dropdown and select the target project or projects.
5. Select which of the following elements to duplicate:
   - Targeting setup
   - Trigger setup
   - Limits setup
   - Theme
   - Translations
6. Click **Duplicate**.
### Duplicate a theme across projects
1. Navigate to *Guides and Surveys > Themes*.
2. Click the **three-dot** menu for the theme you want to duplicate.
5. Click **Duplicate**.
### Re-duplicate a guide, survey, or theme
If you duplicate a guide, survey, or theme to a project that already contains the duplicated content, Amplitude overwrites the content in the target project.
For example, you create a guide (Guide-1) in Project A and duplicate it to Project B. You then make changes to Guide-1 in Project A and want to re-duplicate it to Project B. Amplitude overwrites the original Guide-1 in Project B with the newest version. Amplitude doesn't keep both versions of Guide-1.
When you select the target project, Amplitude applies a badge to show whether the content you're duplicating is new for that project or already exists there. Click into the **Preview changes** section for more information.
## Duplicate across platforms
When you want the same guide or survey on multiple apps (for example, web, iOS, and Android), duplicate it to another platform instead of rebuilding it. When you select **Duplicate** and have multiple platforms configured, Amplitude shows a platform selection modal.
### Duplicate a guide or survey across platforms
3. Click **Duplicate**.
4. In the platform selection modal, select the destination platform or platforms.
The platform selection modal only appears if you have multiple platforms configured. If you have a single platform, Amplitude duplicates the guide or survey without a platform selection step.
Was this helpful?
