Unlimited by category or filter selection. However, your total number of prompts is limited by your pricing tier.
Identical prompts are considered a single prompt, regardless of the LLM. If the prompt is identical across different LLMs, it's still counted as a single prompt towards your usage limit.
Not yet. Amplitude plans on adding Google search volume in the future to provide more context on the popularity of each prompt.
AI Visibility monitors brand performance in OpenAI ChatGPT and Google AI Overviews.
Through the MCP, Amplitude also supports external AI clients such as Cursor for natural-language queries against Amplitude data.
Amplitude's RBAC process uses three layers: roles, permissions, and actions to let administrators assign default or customer roles at the project level. You can assign users and groups to receive view-only, admin, or other permissions sets for each project. This lets you limit who can access each project's AI Visibility analysis.
You can export all prompt metrics as a CSV file. In Amplitude Analytics, you can export charts as PNG, PDF, CSV, or sharable links. Dashboards and usage reports can be exported to PDF or PNG files. All other aspects of Analytics can also be exported.
Yes, if you're logged into the Amplitude system. After you enter new prompts, the system refreshes.
No.
You can identify activity referred to an application from an LLM or conversational AI tool through either the referrer or the utm_source. There is logic for identifying each to the default channel rules. If you already have existing rules, you can replicate this logic within your own rules.
LLM or conversational AI tools don't supply the prompts when users are referred to other applications. You can evaluate entry pages for sessions from LLMs to understand which pages on your site are most commonly receiving direct referrals.
No. AI Visibility looks at the total responses from an LLM or AI.
Unlimited.
Amplitude asks LLMs such as ChatGPT to come up with likely prompts that marketers might be interested in.
Yes, Amplitude provides a native Google Analytics 4 integration.
February 5th, 2026
Need help? Contact Support
Visit Amplitude.com
