Duplicating Across Projects and Platforms
Duplicating a guide, survey, or theme copies it to another project or platform without losing the original. Use duplication when you need the same guide or survey in multiple environments (such as staging and production) or geolocations, or when you want the same experience across web, iOS, and Android.
Duplication in Experiments
You can't duplicate a guide or survey across your projects if it's part of an experiment. If you want the same guide or survey in experiments in multiple projects, you must manually recreate it.
When you duplicate a guide, survey, or theme to a new project, the new project treats the duplicated content as a new entity. Amplitude doesn't copy previous analytics to the new project. Survey duplicates also start with no responses, so their conditional logic is fully editable even if the original's logic is locked due to collected responses. To move a guide, survey, or theme from one project to another, copy it to the destination project, then archive it from the originating project.
Duplicate across projects
Duplicate a guide or survey across projects
- Navigate to Guides and Surveys > Guides or Guides and Surveys > Surveys.
- Click the three-dot menu for the guide or survey you want to duplicate.
- Click Duplicate across projects.
- Click the Destination dropdown and select the target project or projects.
- Select which of the following elements to duplicate:
- Targeting setup
- Trigger setup
- Limits setup
- Theme
- Translations
- Click Duplicate.
Duplicate a theme across projects
- Navigate to Guides and Surveys > Themes.
- Click the three-dot menu for the theme you want to duplicate.
- Click Duplicate.
Re-duplicate a guide, survey, or theme
If you duplicate a guide, survey, or theme to a project that already contains the duplicated content, Amplitude overwrites the content in the target project.
For example, you create a guide (Guide-1) in Project A and duplicate it to Project B. You then make changes to Guide-1 in Project A and want to re-duplicate it to Project B. Amplitude overwrites the original Guide-1 in Project B with the newest version. Amplitude doesn't keep both versions of Guide-1.
When you select the target project, Amplitude applies a badge to show whether the content you're duplicating is new for that project or already exists there. Click into the Preview changes section for more information.
Duplicate across platforms
When you want the same guide or survey on multiple apps (for example, web, iOS, and Android), duplicate it to another platform instead of rebuilding it. When you select Duplicate and have multiple platforms configured, Amplitude shows a platform selection modal.
Duplicate a guide or survey across platforms
- Click Duplicate.
- In the platform selection modal, select the destination platform or platforms.
- Click Duplicate.
The platform selection modal only appears if you have multiple platforms configured. If you have a single platform, Amplitude duplicates the guide or survey without a platform selection step.
Was this helpful?
