On this page
Guides and Surveys Mobile SDK Changelog
4.2.0
Released October 19, 2026. Platforms: Android, iOS, React Native.
Features
  • [Flutter] Add enable, disable, shutdown, setRouter, and unsetRouter SDK methods (GSM-1300).
  • [Flutter] Support listening for Guides and Surveys events through integrations callback in boot options (GSM-1300).
Fixes
  • [iOS] [Android] Video blocks now only play known providers (YouTube, Vimeo, Loom, Vidyard, Wistia, mp4/HLS) in-app; other links open in browser (GSM-1287).
  • [iOS] [Android] Vidyard and Wistia links in video blocks now load as an embedded player (GSM-1287).
  • [iOS] Long titles on classic and showcase guides and surveys now stay clear of the close button GSM-1302.
Performance improvements
  • Chore: upgrade the embedded QuickJS JavaScript engine to the latest release (2026-06-04) [ios, android, rn, flutter]
4.1.0
Released October 8, 2026. Platforms: Android, iOS, React Native.
Fixes
  • [iOS] [Android] Pins and their beacons now respect configured alignment (GSM-1266, GSM-1265).
  • [iOS] Account for scroll position when checking parent clipping (GSM-1269).
  • [iOS] Base64 decoding no longer fails on padded or multi-line input (GSM-1263).
  • [iOS] Multiple same-type rating questions in one survey step now track responses independently (GSM-1199).
  • [iOS] Survey list options are now spaced by the theme's layout gap, matching web (GSM-1200).
  • [Android] Debug log for forwardEvent now shows the full event including properties (GSM-1261).
  • [iOS] Click element combined with another action now triggers SwiftUI onTrigger targets (GSM-1280).
  • [React Native] Add AmplitudeCardEmbedView so inline card embeds take up space in layout.
  • [React Native] SDK settings network check runs in the background instead of freezing the UI at app launch (GSM-1207).
  • [Android] Dangling undismissable Guide could be left on-screen in rare edge case (GSM-1238).
  • [Android] Avoid a rare crash (ConcurrentModificationException) when the foreground activity changes while a guide is showing (GSM-1238).
4.0.1
Released September 21, 2026. Platforms: Android, iOS, React Native.
Breaking Changes (RN only)
  • Engagement SDK methods (boot, enable, disable, forwardEvent, etc.) are now "async" and return a promise. They are still "fire and forget" so in most instances you can safely ignore the returned promise.
Features
  • [Flutter] Add support for card embed (GSM-1241).
  • [iOS] [Android] Support guides and surveys configured with more than one trigger (GSW-1290).
Fixes
  • [Android] Popover talkback focus skips background elements behind nudge whitespace (GSM-1154).
  • [iOS] .amplitudeView no longer breaks Grid layout when applied to a GridRow (GSM-1236).
  • [iOS] The debugger's floating button can no longer be lost off-screen — it can't be dragged past the edge of the screen, and when the app is resized (rotation, Split View, Stage Manager) it moves to the nearest on-screen spot (GSM-1243).
  • [React Native] "When element is tapped" triggers in React Native and other non-UIScene host apps (GSM-1254).
  • [React Native] forwardEvent no longer crashes on Android when an event omits event_id (GSM-1258).
  • [Android] [iOS] Reduce SDK bundle size by minimizing JS bundle and removing Roboto font (GSDK-1213).
  • [React Native] Engagement initialization no longer blocks the main thread; it is done asynchronously (GSM-1207).
3.14.0
Released September 2, 2026. Platforms: Android, iOS, React Native.
Features
  • [iOS] [Android] Support referencing previous steps' survey responses in conditional logic (GSM-1055).
  • [iOS] [Android] Show event property filters in the debugger (GSM-1214).
Fixes
  • [iOS] The debug toolbar no longer breaks when a guide or survey is triggered by smart delay, rage click, user confusion, or no trigger.
  • [iOS] [Android] The debug toolbar keeps working when a guide or survey uses a trigger type your SDK version doesn't recognize yet (GSM-1208).
  • [iOS] No longer crash when a tracked event's event properties contain a Codable Swift value, for example a Codable enum (GSM-1203).
  • [iOS] [Android] Simplify survey's Other textfield keyboard view and dismiss on deselect (GSM-1228).
  • [iOS] Track active window lifecycle synchronously to prevent dangling or uncloseable guides and surveys from being left on the UI (GSM-1196).
3.13.0
Released August 21, 2026. Platforms: Android, iOS, React Native.
Features
  • [iOS] [Android] Support "element is marker" tooltip option (GSM-1123).
  • [iOS] [Android] Support multiple survey questions on a single step (GSM-1050).
Fixes
  • [iOS] [Android] Horizontal layout uses theme gap between media and content (GSM-1174).
  • [iOS] [Android] Fixed-height card embeds keep cta at the bottom (GSM-1173).
  • [iOS] Theme line height applies to guide titles and body content, matching the editor preview (GSM-1192).
  • [Android] Rating questions appear in card embed (GSM-1204).
  • [iOS] [Android] Theme values using em, rem, and % units now apply on device instead of falling back to defaults, matching the editor preview; previously only px worked (GSM-1034).
  • [iOS] refresh() is now "async" and won't interfere with the main thread (GSM-1201).
3.12.1
Released August 13, 2026. Platforms: Android, iOS, React Native.
Fixes
  • [Android] Declare a uniquely-named FileProvider subclass so apps with other dependencies that declare androidx.core.content.FileProvider no longer fail manifest merge (GSM-1194).
3.12.0
Released July 31, 2026. Platforms: Android, iOS, React Native.
Features
  • [Flutter] Flutter release now auto-bumps native iOS and Android SDK pins from the released native SDK versions.
  • [iOS] [Android] Support showcase and split content layouts on mobile (GSM-1126).
  • [Android] Add card embed form factor type (GSM-1135).
  • [iOS] Add card embed form factor type (GSM-1049).
  • [iOS] [Android] Add support for link images (GSM-1144).
  • [iOS] Show a placeholder icon while guide images are loading (GSM-1120).
  • [React Native] boot() now accepts options object with integrations callbacks to forward G+S events to analytics providers other than Amplitude Analytics (GSM-512).
  • [React Native] Add setRouter / unsetRouter SDK methods to React Native for handling in-app navigation from CTA buttons (GSM-1169).
Fixes
  • [iOS] [Android] Announce star rating and selection state to voiceover/talkback (GSM-1155).
  • [Android] Gray out survey cta when a required response is missing (GSM-1151).
  • [Android] Dropdowns won't use crashing material3 apis when app compose version differs (GSM-1147).
  • [iOS] Skip nudge render when dismissed before render completes (GSM-1139).
  • [iOS] [Android] Support CSS named colors in themes (GSM-1035).
  • [iOS] [Android] Theme padding applies to the container, with all content blocks (title, body, images, videos, surveys, buttons) evenly spaced by the theme's "gap" value; existing themes are unaffected (GSM-1127).
  • [iOS] [Android] Include Guides and Surveys mobile SDK version in event properties for "standalone" use case (GSM-1116).
  • [iOS] [Android] Do not show duplicate image when using "vertical split" or "horizontal split" layouts (GSM-1129).
  • [Android] Prevent duplicate debug buttons when navigating between activities (GSM-1159).
  • [iOS] Show one close button on vertical-split popovers and pins with media (GSM-1165).
  • [iOS] [Android] Clean up layouts and media alignment for card embeds and other types (GSM-1141).
  • [iOS] [Android] Images use theme's button corner radius instead of card corner radius (GSM-1164).
  • [iOS] [Android] Card embed border and background match fixed height (GSM-1163).
  • [iOS] [Android] Hide debug button when test user mode is turned off (GSM-1156).
  • [Flutter] Pass mediaUrl through when installing the engagement plugin so media proxy URLs take effect (GSM-1167).
  • [Android] [Flutter] Opening a preview link no longer crashes apps whose activity does not extend ComponentActivity (GSM-1160).
  • [iOS] Recognize taps near the top and bottom edges of a guide with image (GSM-1179).
  • [Android] Hide pin nudge when the target element scrolls fully off-screen (GSM-1180).
  • [iOS] [Android] Reduce image fade-in time (GSM-1181).
3.11.0
Released July 1, 2026. Platforms: Android, iOS, React Native, Flutter.
Features
  • [iOS] [Android] Support "stay on step" CTA action for guides (GSM-1118).
  • [Android] Add fullscreen text input editing ui for modals, popovers, pins with open keyboard (GSM-1056).
  • [iOS] [Android] Add super debugger test user functionality and tests (GSM-892, GSM-1117).
Fixes
  • [iOS] [Android] Render guide content blocks in the order configured in the web builder (GSM-1083).
  • [iOS] [Android] VoiceOver/TalkBack skip background elements; navigate carousel elements on current step (GSM-1112).
  • [Android] Ensure CTA is visible on long nudges (GSM-1056).
  • [iOS] [Android] Use "gap" variable in theme for spacing between title/body and content blocks (existing themes unaffected) (GSM-1113).
  • [iOS] Correct fullscreen keyboard editing layout after device rotation on iOS 26+ (GSM-1107).
  • [iOS] Hide debug button if simulation context fails (GSM-1115).
  • [iOS] Show debug button with error state when simulation context fails to load (GSM-1119).
  • [iOS] Replace view hierarchy polling with event-driven monitoring and ensure it is only done in the foreground (GSM-1125).
  • [iOS] Observe SwiftUI hosting-view layout changes in view hierarchy monitor (GSM-1125).
  • [Flutter] Support "tap element" CTA action (GSM-1029).
  • [Flutter] Support "element tapped" trigger (GSM-1028).
  • [Flutter] Anchor pins to target element when scrolling (GSM-1027).
3.10.0
Released June 11, 2026. Platforms: Android, iOS, React Native, Flutter.
Features
  • [iOS] [Android] Support survey input "prompt" (GSM-1073).
  • [iOS] Add fullscreen text input editing ui for modals, popovers, pins with open keyboard (GSM-1056).
Fixes
  • [iOS] [Android] Apply only theme typography and color to nps survey (GSM-1051).
  • [iOS] Respect custom popover/pin/tooltip widths with media blocks (GSM-1045).
  • [iOS] Ensure orphaned pin guide "marker" is cleaned up (GSM-1087).
  • [iOS] [Android] Style disabled primary buttons (GSM-1080).
3.9.0
Released June 4, 2026. Platforms: Android, iOS, React Native.
Features
  • [iOS] [Android] Support event-based trigger "delay" feature (GSW-552).
  • [Flutter] Support swift package manager (GSM-1048).
  • [iOS] [Android] Support sub_priority field for fine-grained guide ordering within priority buckets (GSW-425).
Fixes
  • [Android] Persist bug report content on device rotation (GSM-1011).
  • [iOS] Add top safe area padding for banner (GSM-1053).
  • [Flutter] SDK not respecting native singleton on android (GSM-1057).
  • [iOS] Ensure Engagement window displays above host app windows (GSM-1061).
  • [iOS] Hide pin nudge when target element is obscured by another window (GSM-1061).
  • [iOS] Ensure pin nudge mask is always cleaned up (GSM-1061).
  • [iOS] [Android] Targeting nudges to users based on the app "version" (GSM-1068).
  • [iOS] Use square corners on bottom of carousel Guide (on mobile phone only) (GSM-1077).
3.8.0
Released May 7, 2026. Platforms: Android, iOS, React Native, Flutter.
Features
  • [iOS] [Android] Support for nudges that trigger after N events in a session (GSW-454).
Fixes
  • [Android] Block TalkBack focus on background elements behind nudge (GSM-1018).
  • [Android] Show selected debug nudge after device rotation instead of original debug nudge (GSDK-937).
  • [Android] Add top safe area padding for banner (GSM-1033).
  • [iOS] Use actualContentSize to position pin arrow (GSM-1040).
  • [iOS] Changing font size when guide/survey is rendered causes elements to become non-tappable (GSM-899).
  • [iOS] Position anchorable nudge UI on main thread after JS callback (GSM-1041).
3.7.0
Released April 28, 2026. Platforms: Android, iOS, React Native, Flutter.
Features
  • [iOS] [Android] Show alert if user attempts to exit bug report before submitting (GSDK-945).
  • [iOS] [Android] [Flutter] [React Native] Add autoRefreshInterval to init options and deprecate passing it through boot options (GSM-1014).
  • [Android] Add debug logs screen and bug report logs (GSDK-911).
Fixes
  • [iOS] Block VoiceOver focus on background elements behind nudge (GSM-1018).
  • [iOS] Lead-align close button when title is trailing-aligned (GSM-1019).
  • [Android] Update text animation to continue after device rotation (GSDK-923).
3.6.0
Released April 15, 2026. Platforms: Android, iOS, React Native, Flutter.
Features
  • [Android] Update UI for debug overlay (GSDK-932).
  • [iOS] [Android] Add debug support and bug report screens (GSDK-913).
  • [iOS] Add debug logs screen and bug report logs (GSDK-911).
  • [Flutter] [React Native] Add updateLanguage SDK method to Flutter & React Native (GSM-358).
Fixes
  • [iOS] [Android] Support for multi-action CTAs in Guides & Surveys.
  • [iOS] [Android] Support for conditional actions in Guides & Surveys.
  • [iOS] Fix flickering on initial pin guide rendering (GSDK-864).
3.5.0
Released April 9, 2026. Platforms: Android, iOS, React Native, Flutter.
Features
  • [Android] [React Native] Add support for HLS video playback for Android (GSDK-924).
Fixes
  • [Android] Reposition debug button so it's not off-screen on device rotation (GSDK-927).
  • [iOS] Fix abort signal crash in super debugger (GSDK-928).
  • [iOS] Fix sequence nudge rendering so text animations don't block each other (GSDK-909).
  • [Android] [React Native] [Flutter] Potential duplicate class errors when a host app also depends on org.commonmark (GSDK-940).
  • [iOS] Ensure font weight is applied to form components and markdown (GSDK-805).
  • [iOS] When CSS system font keywords are specified as the font family in theme, use the system font (GSDK-805).
  • [iOS] Ensure font weight in markdown matches web preview (GSDK-805).
  • [iOS] Reduce SDK bundle size by ~500KB by using variable fonts (GSDK-805).
3.4.0
Released March 31, 2026. Platforms: Android, iOS, React Native.
Features
  • [iOS] [Android] Launch any unarchived guide or survey through debugger (GSDK-893).
  • [iOS] [Android] Add debug mode to periodically reposition pins (GSDK-910).
  • [iOS] [Android] Add debug mode "telltale" to indicate whether events are from and to the G+S SDK (GSDK-912).
  • [iOS] Update UI for debug overlay (GSDK-913).
Fixes
  • [iOS] Reposition debug button so it's not off-screen on device rotation (GSDK-927).
  • [iOS] Fix incomplete banner text animations on device rotation (GSDK-918).
3.3.1
Released March 23, 2026. Platforms: Android, iOS, React Native.
Fixes
  • [iOS] [Android] [React Native] Fix issue causing SDK method screen to not work properly if it was called before the SDK is fully initialized (GSDK-915, assistance-browser PR #1072).
  • [React Native] Remove trailing comma to re-enable Swift 6.0 support.
  • [Android] [iOS] Fix survey content width to match nudge step type (GSDK-908).
  • [Android] Fix banner sizing for phone landscape mode (GSDK-907).
  • [iOS] Fade in banner buttons after text animation completes (GSDK-904).
  • [iOS] [Android] [React Native] Remove unnecessary 1 second delay in screen SDK method (GSDK-898).
3.3.0
Released March 17, 2026. Platforms: Android, iOS, React Native.
Features
  • [iOS] Add theme support for rating button padding (GSDK-803).
  • [Android] [iOS] Fade in buttons after text animation, and add image fade-in (GSDK-889).
  • [Android] [iOS] Refresh SDK on app foregrounded (GSDK-886).
  • [Android] [iOS] Replace reboot call with refresh on session change (GSDK-886).
Fixes
  • [Android] [iOS] Fix animated text showing link syntax while in-progress (GSDK-601).
  • [Android] Fix stuck text when coroutine cancelled mid-animation (GSDK-891).
  • [iOS] Fix misaligned and unclosable tooltip with image (GSDK-890).
  • [iOS] Fix undismissible star and number surveys (GSDK-906).
3.2.0
Released March 6, 2026. Platforms: Android, iOS, React Native.
Features
  • [React Native] Allow "user_properties" to be passed into "boot" SDK method (GSDK-869).
  • [Android] Add theme support for line height (GSDK-820).
  • [Android] Add theme support for rating button padding (GSDK-822).
  • [Android] [iOS] Add theme support form control and button shadows (GSDK-806, GSDK-824).
Fixes
  • [Android] Update step counter for multi-step pins (GSDK-876).
  • [iOS] Use currentParent instead of view when resolving bar in nav hierarchy (GSDK-874).
  • [iOS] Defer pin positioning to correct for layout timing (GSDK-868).
  • [Android] Fix horizontal pin UI and positioning (GSDK-815).
  • [Android] [iOS] Improve in-app support for vimeo and loom videos (GSDK-338, GSDK-861).
  • [Android] Increase nudge width for number surveys with nps-format buttons (GSDK-833).
  • [Android] [iOS] Fix nps and numbers rating wrapping to support theming (GSDK-849).
  • [Android] Add chevron to dropdown list ui (GSDK-239).
  • [iOS] Expand carousel to fullscreen for phones (GSDK-870, GSDK-871).
3.1.1
Released February 23, 2026. Platforms: Android, iOS, React Native.
Fixes
  • [Android] [iOS] Reset survey responses on done or dismiss (GSDK-854).
3.1.0
Released February 13, 2026. Platforms: Android, iOS, React Native.
Features
  • [Android] [iOS] [React Native] On boot, allow "user ID" to be null or blank as long as device ID is specified (GSDK-732).
  • [Android] Add youtube video player (GSDK-856).
Fixes
  • [Android] [iOS] Fix auto-advance logic (GSDK-859).
  • [iOS] Race condition causing pin nudge to be unable to render until the view hierarchy is updated (GSDK-827, GSDK-844).
3.0.0
Released February 11, 2026. Platforms: Android, iOS, React Native.
Breaking changes
  • [iOS] AmplitudeEngagement is now an interface rather than a class. New instances (as of 3.0.0) are created using AmplitudeEngagementFactory.make rather than the AmplitudeEngagement constructor (GSDK-690).
Features
  • [Android] [iOS] [React Native] Add SDK methods disable which temporarily hides any displayed guides or surveys and enable which shows them again (GSDK-513).
  • [React Native] Add SDK method shutdown to React Native SDK binding (GSDK-769).
  • [Android] [iOS] [React Native] Add Minimum SDK version support to App Management so older SDK versions don't initialize Guides and Surveys.
Fixes
  • [Android] [iOS] Fix theming issues (GSDK-845, GSDK-847).
  • [Android] Fix tap outside to close behavior for modals (GSDK-850).
2.1.1
Released February 2, 2026. Platforms: Android, iOS, React Native.
Fixes
  • [React Native] Trailing comma issue causing build error on Swift compiler less than version 6.1.
  • [iOS] Fix keyboard layout bug during iOS 26 device rotation (GSDK-632).
  • [Android] Restore nudge keyboard after configuration change (GSDK-831).
2.1.0
Features
  • [Android] [iOS] Add support for autoRefreshIntervalSeconds option to AmplitudeBootOptions to configure the auto-refresh interval for the SDK (GSDK-799).
  • [Android] [iOS] Add SDK method setAutoRefreshInterval to configure the auto-refresh interval for the SDK on the fly (GSDK-799).
  • [Android] [iOS] Add SDK method refresh to manually trigger a refresh of targeting data (GSDK-799).
Fixes
  • [Android] [iOS] Fix theming issues (GSDK-676).
  • [iOS] Ensure Pin guide is displayed when it follows another guide in a Tour (a multi-step guide) (GSDK-827).
  • [Android] Reposition nudge when keyboard shows (GSDK-782).
  • [Android] Fix link appearance and click behavior (GSDK-821).
  • [Android] Update components to use form control theme (GSDK-835).
  • [Android] Ensure host app still receives touch events after session/activity changes (GSDK-198).
  • [iOS] View hierarchy tracking is now "async" and won't interfere with the main thread (GSDK-819).
2.0.3
Released January 26, 2026. Platforms: Android, iOS, React Native.
Fixes
  • [Android] [iOS] Persist survey values when step-navigating (GSDK-582).
  • [Android] [iOS] Hide buttons until text animation completes, if applicable (GSDK-780).
  • [Android] Popover overlaps system bars because we were not consuming WindowInsets from host app appropriately (GSDK-784).
  • [Android] Crash occurring on transition to a new activity that has enableEdgeToEdge() by waiting for root view to be attached to window (GSDK-768).
  • [iOS] Ensure Modal Guides & Surveys are properly dismissed when shutdown() is called (GSDK-790).
  • [iOS] Update default content alignment to leading GSDK-796.
  • [iOS] Identify containerView as EngagementWindow to dismiss keyboard as needed GSDK-797.
  • [iOS] Expand nudge to show Other textfield without scrolling (GSDK-779).
  • [React Native] Internal engagement Android dependency version is incorrectly set.
2.0.2
Released January 9, 2026. Platforms: iOS.
Fixes
  • [iOS] Compile SDK framework with Xcode 16.2 / Swift 6.0.3 for broader compatibility (GSDK-786).
2.0.1
Released January 7, 2026. Platforms: Android, iOS, React Native.
Features
  • [Android] [iOS] Add ignoreAnalyticsAutomaticScreenTracking option to AmplitudeInitOptions to configure default Engagement SDK behavior for automatic screen tracking (GSDK-750).
Fixes
  • [Android] Reset animation queue when nudge disappears (GSDK-518).
  • [Android] [iOS] Crash in debug mode when used without calling "boot" on the SDK.
  • [iOS] Ensure element selector and preview mode can be started when the other is active (GSDK-717).
  • [Android] [iOS] Ignore Amplitude Analytics automatic screen tracking by default in Engagement SDK (GSDK-781).
2.0.0
Released January 2, 2026. Platforms: Android, iOS, React Native.
Breaking changes
  • [Android] AmplitudeEngagement is now an interface rather than a class, and the options and apiKey are no longer accessible.
  • [Android] [iOS] AmplitudeInitOptions.Options has been removed and logLevel now lives at the top level of the options object.
  • [Android] handlePreviewLinkIntent is deprecated, use handleLinkIntent instead (GSDK-322).
Features
  • [Android] [iOS] Add support for share links (GSDK-322).
  • [Android] [iOS] Add support for custom tooltip size (GSDK-353).
  • [React Native] Add support for serverZone, serverUrl, cdnUrl, mediaUrl, logLevel and locale init options (GSDK-767).
Fixes
  • [Android] [iOS] Pin visibility logic and mask interactions (GSDK-748).
  • [iOS] Allow banner content to expand vertically for tablet (GSDK-759).
  • [iOS] Add finite checks before using actual content size in constraints (GSDK-761).
  • [iOS] Maintain status bar visibility state when nudge shows (GSDK-758).
  • [iOS] Fix arrow misalignment on scrolled pins (GSDK-725).
  • [Android] Gracefully handle failure to initialize mobile SDK, instead of crashing host app (GSDK-775).
  • [Android] Fix theming for step counter size and background color (GSDK-538).
  • [Android] Correctly handle "null" user and device IDs (FOO-2908).
  • [iOS] Remove isObscuredByPresentedViewController check for target view visibility (GSDK-720).
  • [iOS] Tooltip is re-openable after using the "close" button to close it (GSDK-776).
  • [Android] [iOS] Properly apply drop shadow to Guide/Survey cards from theme (GSDK-772).
  • [iOS] Trigger display of matching guide/survey (if any) when user properties are updated through "_setUserProperties" (FOO-2911).
  • [React Native] React Native plugin automatically sets serverZone based on the server zone used for Amplitude initialization (GSDK-767).
  • [Android] [iOS] Hook up nudge position/alignment fields to floating ui and improve arrow styles (GSDK-623, GSDK-684).
  • [Android] [iOS] Fix button height calculation (GSDK-739).
  • [Android] Fix close button foreground color from theme not being applied (GSDK-739).
  • [iOS] Event forwarding from Amplitude Analytics to G+S SDK is now "async" and won't interfere with the main thread (GSDK-763).
1.8.1
Released December 4, 2025. Platforms: iOS.
Fixes
  • [iOS] Update default title+text alignment to leading (GSDK-733).
  • [iOS] Bug causing app crash when Foundation.Data is used as an event property value (GSDK-736).
1.8.0
Released November 26, 2025. Platforms: Android, iOS, React Native.
Features
  • [iOS] Update nudges to be scrollable for long content (GSDK-693).
  • [Android] [iOS] Track nudge engagement event with link source (GSDK-144).
  • [Android] [iOS] Respect modal height setting for carousels+modals on tablets.
Fixes
  • [Android] Fix nps button height (GSDK-708).
  • [iOS] Re-render mask + target view on device orientation changes (GSDK-441).
  • [Android] Use theme background color for top+bottom of Carousel (GSDK-731).
  • [iOS] Background mask for pins flickers when advancing between steps (GSDK-660).
  • [iOS] Guide renders in top-left corner briefly before being moved to correct location (GSDK-718).
  • [Android] Drop shadows on form factors is clipped and duplicated by Surface (GSDK-259).
  • [iOS] Add support for conditional actions on button blocks (GSDK-726).
  • [Android] Update spacing between ctas (GSDK-734).
1.7.1
Released November 21, 2025. Platforms: iOS.
Fixes
  • [iOS] Additional logging for the isObscuredByPresentedViewController pin Guide target check, and flash a red background on the obscuring view to aid debugging (GSDK-720).
1.7.0
Released November 18, 2025. Platforms: Android, iOS, React Native.
Fixes
  • [React Native] Type error when using the Engagement Analytics Plugin with "amplitude.add(...)" (GSDK-698).
  • [Android] Guide title incorrectly center-aligned when left alignment was configured (GSDK-701).
  • [Android] Allow underscore ("_") separated font files on Android (GSDK-701).
  • [Android] Use correct corner radius and outer padding when rendering Guide (GSDK-701).
  • [iOS] App is unresponsive after displaying StoreKit content (for example, manageSubscriptionsSheet) (GSDK-699).
1.6.1
Released November 13, 2025. Platforms: Android, iOS, React Native.
Fixes
  • [Android] [iOS] Update ordering of survey and media blocks (GSDK-689).
  • [iOS] Fix threading issue for uikit click element (GSDK-571).
  • [iOS] Fix nudge anchoring on custom nav bar behind transparent system nav bar (GSDK-664).
  • [Android] Refactor view hierarchy scanning to improve performance on the Main thread.
1.6.0
Released November 7, 2025. Platforms: Android, iOS, React Native.
Features
  • [Android] [iOS] Proxy support (GSDK-630). Go to Proxy.
  • [Android] [iOS] Support 4 new popover Guide positions (top-center, bottom-center, left-center, right-center) (FOO-2639).
Fixes
  • [Android] [iOS] Add debug logging to all SDK methods.
  • [Android] Proper handling of null or blank user IDs on boot (GSDK-681).
  • [Android] Theming fixes (incorrect colors, text alignment, popover Guide width, and so forth.) (GSDK-671).
  • [Android] When pin target scrolls offscreen, guide should be displayed again when target re-appears (GSDK-651).
  • [iOS] [Android] On tablets, modal carousel max width in theme is used, rather than device's max-width (GSDK-633, GSDK-616).
  • [iOS] Stop showing previously previewed guide when initiating a new preview (GSDK-595).
  • [iOS] Ensure URLs opened in browser are opened on main UI thread (GSDK-652).
  • [Android] Odd whitespace appears when Guide content is right-aligned (GSDK-647).
  • [iOS] Automatically call shutdown() when the user ID is set to nil through Amplitude Analytics SDK (#436).
  • [iOS] Modal Guide moves from centered to top left of screen (GSDK-627).
  • [iOS] App hangs when executing a callback through a CTA button (GSDK-458).
  • [iOS] Banners using text animations have blank text (GSDK-638).
  • [iOS] Tooltip markers not staying with their targeted element when scrolling vertically (GSDK-607).
  • [iOS] Tooltip appearing without pointer (GSDK-607).
  • [iOS] User-driven dismissal of tooltip should NOT hide the tooltip marker (GSDK-607).
  • [iOS] Ensure user properties passed to analytics.identify are used for Guide user property interpolation (#415).
  • [iOS] Prevent flickering for tooltips and closed-by-default pins (GSDK-659).
  • [iOS] Allow pins to target navbar elements (GSDK-664).
  • [iOS] Close button ("x") padding uses value from theme (GSDK-661).
  • [iOS] Images sometimes not loading (GSDK-656).
  • [Android] Add padding below bottom content on nudges (GSDK-687).
1.5.2
Released October 31, 2025. Platforms: iOS, React Native.
Fixes
  • [iOS] [React Native] Crash when calling setUserId.
1.5.1
Released October 30, 2025. Platforms: Android, iOS, React Native.
Breaking changes
  • [Android] [iOS] The cleanup() and reboot() functions have been removed, use shutdown() instead.
Fixes
  • [Android] [iOS] [React Native] Ensure shutdown() removes all active nudges from view.
  • [Android] [iOS] [React Native] Ensure non-JSON-safe values are serializable.
1.5.0
Released October 21, 2025. Platforms: Android, iOS, React Native.
Breaking changes
  • [Android] [iOS] [React Native] Require calling shutdown() before calling boot() with a new user ID.
Features
  • [Android] [iOS] Custom font support (GSDK-578, GSDK-620).
  • [Android] Analytics plugin tracks changes to user ID (#355).
  • [Android] [iOS] Support links and italics in Guide titles (GSDK-600).
Fixes
  • [iOS] Multiple crashes involving QuickJS (GSDK-640, GSDK-625).
  • [Android] Crash when rendering Guides in Android apps with multiple Activity or "plain" Activity (for example, not AppCompatActivity) (GSDK-589).
  • [iOS] Crash on preview when using Debugger (#337).
  • [iOS] "Arrow" for tooltip Guide not hiding when tooltip is closed (GSDK-609).
  • [iOS] Carousel Guide is correct size on large (tablet) screens (GSDK-616).
  • [iOS] Pin form factor "offset" positioning + alignment bugs (GSDK-593).
  • [iOS] Modal and popover Guide snaps to the top-left rather than remaining in the configured position (GSDK-627).
  • [Android] [iOS] [React Native] A race condition which could cause a Guide to be un-dismissable (#355).
  • [Android] Condition causing duplicate carousel Guides (GSDK-641).
  • [iOS] Text animations not always rendering properly (GSDK-638).
  • [Android] [iOS] Issue causing Dark Mode theme to not be used, or incorrect colors to be used (GSDK-596, GSDK-612).
  • [Android] [iOS] Remove extra spacing when actions are hidden (GSDK-421).
  • [Android] Possible issue with "smart delay" trigger (GSDK-605).
  • [iOS] Guide title font weight now defaults to semi-bold (GSDK-615).
Was this helpful?
