On this page
Explore a Metric Explorer data point with Microscope
Microscope opens when you click a data point on a Metric Explorer chart. It acts on the users or groups behind that one point, for that metric and interval. Use it to move from a number on the chart to the people behind it: who they are, what they did next, what their sessions looked like, and how to act on them.
Open Microscope on a data point
  1. Hover over the series you want to inspect. On a busy chart, clear the other series in the breakdown table first to make clicking easier.
  2. Click a data point. The Microscope menu opens with the actions available for that metric.
Microscope actions in Metric Explorer
Which metrics offer which actions
The actions depend on the type of metric you click:
  • Event metrics and session metrics: The actions in the table. For a session metric, the users are those whose sessions make up the point.
  • Formulas: A formula's value comes from several metrics, so it has no single set of users. To inspect the users behind a formula, turn on Show in results for one of its input metrics and click a point on that input.
  • KPI visualization: Download Users, Create Cohort, and Show Journeys.
Actions that list users are unavailable on points with a value of zero.
Find users who abandoned a cart
This example turns a session metric into a reusable audience:
  1. Add Add to Cart measured as Total Sessions, with + Filter by > [Amplitude] Contains Event > Purchase = 0.
  2. Click the point for the day you want to inspect.
  3. Click Create Cohort and name the cohort, for example Abandoned cart: last 7 days.
  4. Use the cohort as a segment in other charts, or click the point again and use Add Users to… > Guide to show those users a reminder.
For Microscope behavior across all Amplitude charts, including user streams and conversion drivers, go to Microscope.
Was this helpful?
