On this page
Work with branches
A branch in Amplitude Data is a point-in-time copy of your tracking plan that you and your team edit privately, without exposing the changes to anyone else until you merge them back into the main tracking plan. If you've used Git, the model works the same way: you isolate changes on a branch, then merge them when they're ready.
When you first create your Amplitude Data account, Amplitude automatically creates a default branch called main. It includes a few sample events and properties to get you started. Think of the main branch as your production branch: it contains your latest official tracking plan and matches what's instrumented in your default branch in Git (typically master or main).
main is suitable for getting started in Amplitude Data, and you may find that it's the only branch you need for some time.
Publish a version of your tracking plan
A branch initially keeps the changes you make in its staging area, where they remain pending. Pending changes are work-in-progress changes: visible to you and your teammates, but hidden from your production systems and not yet available for instrumentation by your engineering team.
When your pending changes are ready, publish them. Publishing your changes creates a new version of your tracking plan that includes those changes. Publishing also exposes that new version to your engineering team for instrumentation. If your new version is on the main branch, those changes also propagate to your production systems.
Every new version has a version number and an optional description, so you can tell versions apart later. Version numbers start at 1 and increment by 1 each time you publish a new one.
Every branch has its own tracking plan versions, which means it's possible to have two versions of the tracking plan with the same version number: one in main, and one in your own branch. When this happens, Amplitude Data always displays the name of the branch to avoid confusion.
Create and delete branches
As you and your team ramp up your use of Amplitude Data, you may outgrow the main branch and need a more robust workflow. This usually happens when:
  • Too many people are making changes to main at the same time, or
  • Feature teams want their own separate copy of the tracking plan to collaborate in, review their work, and get stakeholder approval.
In Amplitude Data, all branches spawn from main and merge back into main.
To create a new branch, follow these steps:
  1. Click main in the page's header.
  2. Type the name of the branch you want to create.
  3. Click +.
  4. In the Create branch modal, confirm the name of your branch, add an optional description, and click Create.
    If you have pending changes on main, you can either take those changes with you into your new branch, or leave them behind on main.
To delete a branch, follow these steps:
  1. Click the X next to the branch name.
  2. In the modal that appears, click Delete to confirm your choice.
Work on a branch
After your branch exists, working with it is like working with main. You and your team can create and publish new versions, instrument those versions in the product, and report back to the branch on the status of the instrumentation.
This can all happen in parallel with other teams working in their own branches, without any impact on you.
From time to time, refresh your branch with any changes made to main since you created your branch. If Amplitude Data detects that your branch is out of date with main, you see a Refresh button in the page's toolbar. Click it to get caught up.
Merge your branch back into main
When you're happy with the changes you've made on your branch, merge them back into main. This typically happens when your product team is also ready to merge their changes into the main branch in Git.
There are a few prerequisites to address before you can successfully merge:
  • You must publish all pending changes on your branch.
  • Your branch must be up to date with main.
  • main must have all its pending changes published as well.
To publish your changes to a new version on your branch, follow these steps:
  1. In the left sidebar, click Save changes.
  2. In the Save changes modal, review the pending changes. If everything looks correct, click Save.
To merge, follow these steps:
  1. Go to Activity. You may have to click Refresh.
  2. Click Approve.
  3. Click Merge.
If your project requires team reviews, you may not have permission to merge directly. In this case, you must first create a merge request. A merge request is a way to ask stakeholders outside your team to review your changes and give their explicit approval. Only team members with Manager or Admin permissions can approve changes; do so by logging into Amplitude Data and clicking Merge in the page's toolbar.
Anyone on your team can then merge an approved merge request.
Copy branch changes to testing environments
After you apply changes to a branch, you can copy those changes to other projects or environments for testing.
To copy branch changes, follow these steps:
  1. Go to Activity > Branch Changes from the branch you want to copy.
  2. Click Copy Branch.
  3. In the modal that appears, select the testing projects to copy the branch to from the dropdown. Then click Copy.
  4. After the copy completes, click the notification to review the copied branch.
  5. Review changes to the testing project. If changes look as expected, click Merge.
Managers and Admins can also restrict which projects can accept copies of branch changes.
To restrict branch copying, follow these steps:
  1. From the source project, go to Settings > General.
  2. Select the checkbox next to Restrict branch copying to specified testing projects.
  3. From the dropdown, select the checkbox next to the projects where other Amplitude users can save copies of branch changes.
Was this helpful?
