How Amplitude handles segmenting on a user property in a Funnel Analysis chart
When you segment the data on a user property, Amplitude applies the segmentation to the first step of your funnel.
For example, suppose Event A is the first step of your funnel, and a user triggered:
- Event B with the user property
[Amplitude] Country=Canada; and then - Event A with the user property
[Amplitude] Country=United States
If you segment by Active country(s), Amplitude shows this user in the [Amplitude] Country = United States segment in the Event A step.
Was this helpful?
